SivaKona
4 years agoCannot place ALERT# in DQS group Error for External Memory Interfaces Intel Stratix 10 FPGA IP
We are working on Quartus Version : Quartus Prime Version 21.1.0 Build 169 03/24/2021 SC Pro Edition
Target Device: 1SG280HU2F50E2VG
Added "External Memory Interfaces Intel Stratix 10 FPGA ...
sstrell
4 years agoAs noted, did you synch the system infos after you made the parameter change? Just click Sync System Infos at the bottom of Platform Designer.
- SivaKona4 years ago
Hi sstrell,
"Sync System infos" also did not change the behavior. Got same Errors as before.
Following is the snapshot of the messages around first Error
Siva Kona
