Can some command do import CSV file?
- 4 years ago
Unfortunately, to import assignments, there is currently no other way other than Assignment > Import Assignments.
How many .csv file that you plan to import? Shouldn't it better if you export the assignment from other project into a single .csv file before import to your current project?
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos and select the best solution.
I guess you can keep track all your .csv in an excel sheet or One Note in order to know which has been imported.
You can then remove all assignment and start clean by import the necessary assignment.
I believe I have answered your question. With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
Hi RichardTanSY_In
Thank you, RichardTanSY_In
OK. Thank you very much.
