Can some command do import CSV file?
- 4 years ago
Unfortunately, to import assignments, there is currently no other way other than Assignment > Import Assignments.
How many .csv file that you plan to import? Shouldn't it better if you export the assignment from other project into a single .csv file before import to your current project?
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos and select the best solution.
Richard Tan
Hi RichardTanSY_In
Thank you, RichardTanSY_In
OK, I get it. Thank you very much.
I have much the same type PCB boards to connect FPGA pins and sockets.
But some sockets are broken. So, I need to change the pin assignment to connect workable sockets.
Therefor, I have many CSV files.
