Eugeny_Brychkov
7 years agoCan I program active serial device other than Altera's one using Quartus (programmer) through cable?
I am going to replace EPCS16 with W25Q128FVSIG - due to cost and size reasons. I have already successfull programmed W25Q through cable using my own hardware and software and made FPGA configuring fr...
Safila
4 years agoHi,
We are using ArriaV 5AGXMB1G4F40 FPGA in our design.Earlier,the flash device used was “S25FL512”.Since the part is not available , we have replaced “W25Q512JVFIM”.
While converting .sof to .jic using Quartus,the above mentioned flash has not listed as default.Therby,we have add the flash in the wizard under ” add device” category.
After conversion,tried to flash .jic.We could able to program .jic successfully[Quartus programmer_v19.1 displays the status as successful].But config_done has not set.
Kindly help us on this issue.
