stiner282
4 years agoBounding Question "Right Bound must be a constant"
I am currently building an n-bit shifter using VHDL. I have the code working in modelsim where it compiles just fine. But as soon as I try to bring it over to Quartus it gives the error: Error (10454...
sstrell
4 years agoIt's not clear which line is line 68 from the way you posted, but I think you should be using the variable you created, shiftr, in the process instead of shiftamt.
