14 years agoHi All;
As a continuing thread to this discussion, I've provided a link to the video that I did last year on a PySide/Python GUI for automatic VHDL code generation. This GUI is built with Python and Qt/PySide. The only other python module used is Mako, where all the other functions are built with the standard library, such as regular expressions. However, another engineer and I put together a rapid application framework for building such GUI's, and we called it PyRad. The idea is that once a solid VHDL library or libraries modules are designed, then designing at the higher level with either a GUI or API based on python would allow for assembly of modules & rapid design. The programming paradigm is declarative. p.s. There is a full screen button on the lower right of the video. Press this to see the GUI in the greatest detail. http://www.viddler.com/explore/james_atlantix/videos/11/?secreturl=100698896 James
