9 years agoassertion failed! Pin_memory problem.
Hi I'm encountering an assertion failed problem. The returned message is "MMD FATAL: acl_pcie_dma_windows.cpp:381: WDC_DMASGBufLock function failed." I looked into the acl_pcie_dma_windows.cpp f...
8 years agoIf the environmental variable is set correctly, you will see lots of messages from quartus_pgm during host execution that starts the programming process through JTAG and finishes it (which can take up to 30 seconds) and then your kernel is executed. Did you see these messages? On my environment those messages are especially printed out in green, but I use Linux and things might be different on Windows.
