9 years agoassertion failed! Pin_memory problem.
Hi I'm encountering an assertion failed problem. The returned message is "MMD FATAL: acl_pcie_dma_windows.cpp:381: WDC_DMASGBufLock function failed." I looked into the acl_pcie_dma_windows.cpp f...
8 years agoHi HRZ
Thank you for the reply. I tried forcing JTAG-based reconfiguration as you mentioned using " set ACL_PCIE_USE_JTAG_PROGRAMMING=1", but the same problem still exist. Is it because that it's still transferring data via PCIe at runtime or am I not forcing it correctly? Thank you.
