8 years agoALT_SLD_FAB error
edit: I solved the problem. I changed the operating system language of my computer from Turkish to English and it worked. Hello, I have been using Quartus Prime 17.0v. When I compile...
johnnyfan1979
4 years agoMaybe you can check the Environment Variables of the "IP_ROOTDIR".
Make sure it is set to the correct Quartus path on your host such as IP_ROOTDIR=F:\intelFPGA\20.1\ip
