NuvKFC
Contributor
4 years agoalias of pin assignment
I have a pin_assign.csv file.
Unfortunately, the pins name in the pin_assign.csv file are too complex.
Can I set some alias or some command in the pin_assign.csv file?
Thank you very much.
- 4 years ago
Hi KF Cc,
I did not read you question properly.
Assuming I understand it correctly, I don't think yes because Quartus will use the exact pin names according to the csv when you import it. Assigning an alias will lead to unknown pin assignment as Quartus not able to detect it.
SyafieqS
4 years agoHi KF Cc,
NuvKFC
Contributor
4 years agoHi SyafieqS
Thank you, SyafieqS, very much.
I want to add alias into CSV file because the pad name is too complex.
From your answer, this requirement can't be met.
I get it.
