NuvKFC
Contributor
4 years agoalias of pin assignment
I have a pin_assign.csv file.
Unfortunately, the pins name in the pin_assign.csv file are too complex.
Can I set some alias or some command in the pin_assign.csv file?
Thank you very much.
- 4 years ago
Hi KF Cc,
I did not read you question properly.
Assuming I understand it correctly, I don't think yes because Quartus will use the exact pin names according to the csv when you import it. Assigning an alias will lead to unknown pin assignment as Quartus not able to detect it.
SyafieqS
4 years agoHi KF Cc,
May I know if there is any update from my previous reply
NuvKFC
Contributor
4 years agoHi SyafieqS
Thank you, SyafieqS, very much. Sorry that I forgot this questions.
What is command function?
I use the CSV file imported method to assign pin location like following picture. Does there have command function?
