NuvKFC
Contributor
4 years agoalias of pin assignment
I have a pin_assign.csv file.
Unfortunately, the pins name in the pin_assign.csv file are too complex.
Can I set some alias or some command in the pin_assign.csv file?
Thank you very much.
- 4 years ago
Hi KF Cc,
I did not read you question properly.
Assuming I understand it correctly, I don't think yes because Quartus will use the exact pin names according to the csv when you import it. Assigning an alias will lead to unknown pin assignment as Quartus not able to detect it.
SyafieqS
4 years agoKF C,
Are you referring to what command function?
You can use a assignment to import assignment of the csv file list of your pins
