Agilex gated clock conversion
- 3 years ago
[First Post Edited]
Had to use both:
set_global_assignment -name SYNTH_GATED_CLOCK_CONVERSION ON
set_global_assignment -name SYNTH_GATED_CLOCK_CONVERSION_BASE_CLOCK ON
Then Following design synthesis, view the results of gated clock conversion in the Gated Clock Conversion Details report (.syn.rpt under Gated Clock Conversion Details). The report lists all converted and unconverted gated clocks with their base clocks. For unconverted gated clocks, the report specifies the reason the clock is not converted.
Sheng
Use this set_global_assignment -name SYNTH_GATED_CLOCK_CONVERSION_BASE_CLOCK ON
Sheng
