9 years agoAdded a few constraints to .sdc file and the whole design broke?
Hello, I am using the Arria 10 Dev. Board to test out the transceivers. I have a simple design using the Arria 10 Transciever Native PHY with enhanced PCS as well as the associated reset core and...
9 years agoSince I was curious, I tried reducing the REFCLK to 63.75MHz--the lowest allowed by the Transceiver PLL. The results were the same--one failing path and transmissions were garbled.
