ADC Toolkit: No associated hardware detected
Anyone???
Hi there, which quartus version are you using? One thing you can do is to revert back to an older Quartus version and see if that works? If it doesnt, then probably it has nothing to do with the version but rather the design itself.
For "No associated hardware detected", try closing the System Console first --> Goto Programmer --> program the sof into the device --> Run System Console.
- JonWay_altera5 years ago
You can also use this design: https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/max-10-adc-with-threshold-violation-detection/
This is the same implementation as the youtube how to video with additional threshold violation detection.
As a sanity check, download Quartus programmer v16.0, and use the system console to run the design. Make sure that it works.
Then you can try the same design with the newer Quartus version you have installed.
This way, you can rule out if this is a Quartus version issue or design issue.
- paulw75 years ago
I opened the design you gave me the link to, and it compiles ok. However, my pin assignments are different, so I move the clock and reset to the pins assigned on my board and I try to compile. It fails with this:
Error (170084): Can't route signal "ADC2_PLL:pll|ADC2_PLL_altpll_5q22:sd1|wire_pll7_clk[0]" to atom "ADC2_ADC:adc|altera_modular_adc_control:control_internal|fiftyfivenm_adcblock_top_wrapper:adc_inst|fiftyfivenm_adcblock_primitive_wrapper:adcblock_instance|primitive_instance"
My version is 20.1.1 Build 720 SJ Lite Edition
I think you will have to either Upgrade the IP or rebuild (instantiate the newer IP to replace the old one). Then try compiling again.
