ADC Toolkit: No associated hardware detected
I'll add some more info, I was following: https://www.youtube.com/watch?v=0oO1RFa-4Xk
There were a couple of differences along the way, like instead of Qsys, I'm using Platform Designer and instead of 'Altera Modular ADC Core' it's named 'Modular ADC Core Intel...'. So obviously there have been changes since the tutorial.
Another thing to add, when I load up System Console, I get some messages and there are some red crosses and I don't know what they mean, see image.
Can anyone help with this?
Anyone???
- JonWay_altera5 years ago
Hi there, which quartus version are you using? One thing you can do is to revert back to an older Quartus version and see if that works? If it doesnt, then probably it has nothing to do with the version but rather the design itself.
For "No associated hardware detected", try closing the System Console first --> Goto Programmer --> program the sof into the device --> Run System Console.
You can also use this design: https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/max-10-adc-with-threshold-violation-detection/
This is the same implementation as the youtube how to video with additional threshold violation detection.
As a sanity check, download Quartus programmer v16.0, and use the system console to run the design. Make sure that it works.
Then you can try the same design with the newer Quartus version you have installed.
This way, you can rule out if this is a Quartus version issue or design issue.
- paulw75 years ago
I opened the design you gave me the link to, and it compiles ok. However, my pin assignments are different, so I move the clock and reset to the pins assigned on my board and I try to compile. It fails with this:
Error (170084): Can't route signal "ADC2_PLL:pll|ADC2_PLL_altpll_5q22:sd1|wire_pll7_clk[0]" to atom "ADC2_ADC:adc|altera_modular_adc_control:control_internal|fiftyfivenm_adcblock_top_wrapper:adc_inst|fiftyfivenm_adcblock_primitive_wrapper:adcblock_instance|primitive_instance"
My version is 20.1.1 Build 720 SJ Lite Edition
