8 years ago*** Fatal Error: Access Violation at 0X000000005DD8C080
I have a board with Altera CycloneIII EP3C40F780C7N FPGA installed and Numonyx StrataFlash 4400P0VB0E attached.
All the time when I try to save downloaded flash image (examine) over Quartus Programmer it shows the issue - *** Fatal Error: Access Violation at 0X000000005DD8C080 Could you please advise what could be the cause of the problem? Quartus II 64-bit version 13.0.1 Build 232 06/12/2013 SJ Web Edition used. below is the trace: *** Fatal Error: Access Violation at 0X000000005DD8C080 Module: quartus.exe Stack Trace: 0x3c07f: memcpy + 0x11f 0x13963: PGMIO_PCF_FILE_INFO::get_prog_mode_mask + 0x153 0x4359c: PGM_CHAIN_ELEMENT::create_flash_map_from_bitfield + 0x6bc 0x5fc0f: pgmwq_select_hardware_and_close + 0x796f 0x6adc9: pgmwq_select_hardware_and_close + 0x12b29 0x6e066: pgmwq_export_device_dlg + 0x1a76 0x784a4: pgmwq_export_device_dlg + 0xbeb4 0x11eb5a: QMetaObject::activate + 0x53a 0xdd2f: QAction::activate + 0xdf 0x3b3447: QMenu::findIdForAction + 0x327 0x3b9c21: QMenu::internalDelayedPopup + 0x8c1 0x6a164: QWidget::event + 0xd4 0x3b9fb2: QMenu::event + 0x2a2 0x228f5: QApplicationPrivate::notify_helper + 0xf5 0x241ab: QApplication::notify + 0x70b 0x10a7c1: QCoreApplication::notifyInternal + 0x71 0x2371c: QApplicationPrivate::sendMouseEvent + 0x1ec 0x812ba: QApplication::winFocus + 0x9da 0x83f4c: QApplication::restoreOverrideCursor + 0x93c 0xbc4f: CallWindowProcW + 0x4cf 0xb5ce: DispatchMessageW + 0x1ae 0x132f69: QEventDispatcherWin32::processEvents + 0x3b9 0x83564: QApplicationPrivate::translateTouchEvent + 0x884 0x109cf0: QEventLoop::exec + 0x230 0x3b8006: QMenu::exec + 0x76 0x6a5f0: QWidget::event + 0x560 0x380d06: QFrame::event + 0x36 0x46ae14: QAbstractItemView::viewportEvent + 0x4b4 0x10a932: QCoreApplicationPrivate::sendThroughObjectEventFilters + 0x82 0x228e1: QApplicationPrivate::notify_helper + 0xe1 0x24556: QApplication::notify + 0xab6 0x10a7c1: QCoreApplication::notifyInternal + 0x71 0x816a4: QApplication::winFocus + 0xdc4 0x83f4c: QApplication::restoreOverrideCursor + 0x93c 0xbc4f: CallWindowProcW + 0x4cf 0xb5ce: DispatchMessageW + 0x1ae 0x132f69: QEventDispatcherWin32::processEvents + 0x3b9 0x83564: QApplicationPrivate::translateTouchEvent + 0x884 0x109cf0: QEventLoop::exec + 0x230 0x10e5ff: QCoreApplication::exec + 0xdf 0x4c78: msg_exe_fini + 0x58 0x53bc: msg_exe_fini + 0x79c 0x1584: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194 0x5f9f: msg_exe_main + 0x8f 0x12773: BaseThreadInitThunk + 0x13 0x70d50: RtlUserThreadStart + 0x20 End-trace Quartus II 64-Bit Version 13.0.1 Build 232 06/12/2013 SJ Web Edition Service Pack Installed: 112 Replies
Tried today Quartus and Programmer Pro version 17.1 - the same issue (didn't help)...
- butterdog
I have the same problem as you. Has the problem been solved?
