14 years agowaitrequest signal for Avalon MM Slave
I have created a custom Avalon MM Slave component with SOPC v10.1 which uses chipselect_n, read_n, write_n, address/data, and waitrequest. Long story short I need it to be variable wait states so th...
14 years ago --- Quote Start --- The Slave is written in VHDL. --- Quote End --- Do you have a full-edition of Modelsim, i.e., can you run mixed-language simulations? --- Quote Start --- The master is the Nios processor and the Nios is accessed via either running C code: my_reg = IORD_8DIRECT (MYCUSTOM_MM_INTERFACE_BASE, 0x800); --- Quote End --- Does your simulation perform this same action using a NIOS processor? --- Quote Start --- I'm not familiar with the other method of using a JTAG-to-Avalon-MM master for debugging - does this mean no CPU at all? --- Quote End --- Its another master. I use it without a CPU, but in your case, you could add it to the SOPC system and use it in addition to the CPU. --- Quote Start --- I think of the trace signals as being the "real thing" and the simulation as being...just that...a simulation. --- Quote End --- In the case that you simulate exactly what you implement in hardware, the two will match. Its not clear from our discussion that your simulation and hardware are identical. So lets establish that first. --- Quote Start --- While I'm not saying by any means the sim is not useful - my sim works fine and yet the target has this strange behavior. In my simulation of the master I deassert chip select on the rising clock edge after waitrequest is deasserted - and that just plain works. --- Quote End --- But why in your simulation do you have your own master. Why not simulate with the NIOS processor in the design? --- Quote Start --- why would the CPU stall forever if waitrequest goes low, as it does? --- Quote End --- I agree, its a strange problem, and the first thing I would do would be to put the same design into the simulator and try and understand if there is a difference between simulation and 'real' hardware. --- Quote Start --- I did try inserting the BFM (never used it before and I don't know Verilog or system Verilog) but I was finding the documentation on how to make use of it - very poor. --- Quote End --- Yes, I agree, the documentation is not very good. Especially for simulation of VHDL designs, its downright painful ... That is why I am offering to give you an example. But you need to let me know if you can implement mixed-mode language simulation ... Just to be clear; I'm not telling you that what you are trying to do is wrong, I'm just trying commenting on how I would attack this problem. My recommendation - simulate exactly what is in the hardware, including the NIOS II processor, or use an independently created BFM master, that way you don't have your own incorrect assumptions (or incorrect Altera documentation) folded into both your master and your slave. Cheers, Dave
