15 years agoUsing custom instruction from uCLinux user app on nios2mmu
Hello, Is it possible to use a custom instruction from an user application running on NIOS2MMU - uCLinux. I'm trying to run the CRC design example on uCLinux. When I try to compile the ...
15 years agoYes, I think the results of the combinatorial ALU block are written into a 2? entry fifo along with the register number as well as being written to the register file itself.
The values from this fifo take precidence over the values read from the register file itself. This makes the values from single cycle ALU instructions available in the following instruction. The results of load and potentially multi-cycle instructions are not fed into this fifo - so force pipeline stalls (it is possible that the results aren't ready early enough in the clock cycle to do this without significantly reducing fmax). Load and store instructions are always fully synchronous - they both wait for the Avalon bus transfer to complete. I'm sure the bus interface could trivially do a single async write (would give an asyc fault on error). Async read is somewhat harder - a pipeline stall would be needed to do the delayed write to the register file. Possibly they could have done non-delayed reads from tightly coupled data memory - after all the memory read of 'rA + imm16' can be scheduled unconditionally for all tightly coupled data blocks.
