14 years agoStrange Nios latency
I have SOPC Nios system with onchip_mem. Program (resides in onchip_mem) works very slowly. In SignalTab I see strange Nios latency. Time between two simple writes is 48 Nios clock cycles! Wh...
14 years agoYou've not said which cpu you are using (/f /s or /e).
Are you executing the code out of tightly coupled memory, or via the instruction cache? If you are using the instruction cache and are looking at the first 2 writes, then there may be instruction cache fills taking extra time. In that case, the times between the later writes would be faster. The /f cpu will execute 1 instruction every clock (from tightly coupled instruction memory or instruction cache). 11 clocks is somewhere near the value for a clock crossing bridge (10 clocks??). I've measured 3 clocks for Avalon MM transfers to local PIO (1 clock delay configured for reads and writes), on chip memory might to 0 clock delay writes.
