14 years agosopc2dts: cfi-flash & usb isp1362-hcd
Hey nios2-community,
I want to update my kernel from version 2.6.35 to version 3.3, but i have some problems integrating cfi-flash and usb. I'm working with a custom board similar to the neek-board and IP-Cores from Altera (mostly). Furthermore i'm using the neat tool: sopc2dts, which is a great help, but i'm not sure if i made some mistakes regarding the configuration of the device-tree. 1) cfi-flash: Everytime i use flashcp or ioctls accessing the otp-register my system freezes. Nevertheless i can create a jffs2-filesystem on my older build and use that on my new build. So i can mount the jffs2 on kernel 3.3 and make everything with the files on it. The system just hangs when i access the flash directly over the flash-utilities and/or ioctls. (the ioctl is changing the mode of cfi-flash to MTD_OTP_FACTORY) I generated my device-tree with sopc2dts and the configuration regarding the cfi-flash seems to be just right. This is the entry about cfi-flash:
cfi_flash: flash@0x4000000 {
compatible = "ALTR,cfi_flash-9.0", "cfi-flash";
reg = < 0x04000000 0x02000000 >;
bank-width = < 2 >;
device-width = < 1 >;
# address-cells = < 1 >;
# size-cells = < 1 >;
Linux-Kernel@0 {
reg = < 0x00000000 0x00800000 >;
}; //end Linux-Kernel@0
filesystem@1000000 {
reg = < 0x01000000 0x01000000 >;
}; //end filesystem@1000000
}; //end flash@0x4000000 (cfi_flash)My kernel-configuration is: -> MTD (x) -> MTD_OF_PARTS (x) -> CONFIG_MTD_CHAR (x) -> MTD_BLOCK (x) -> RAM/ROM/Flash chip drivers -> MTD_CFI (x) -> MTD_CFI_ADV_OPTIONS (x) -> MTD_OTP (x) -> MTD_CFI_INTELEXT (x) -> Mapping drivers for chip access -> CONFIG_MTD_PHYSMAP_OF (x) -> BLK_DEV (x) 2) My USB-device isn't working anymore. It fails when checking the clkrdy signal at isp1362-hcd.c. This is really weird, because everything that was in the header-file nios2 in my older build is also in the device-tree. Here is the entry in my device-tree:
isp1362_usb_controller: usb@0xa80 {
compatible = "nxp,isp1362-1.0", "nxp,usb-isp1362";
reg = < 0x00000A80 0x00000008
0x00000B28 0x00000001 >;
interrupt-parent = < &cpu_linux >;
interrupts = < 10 11 >;
}; //end usb@0xa80 (isp1362_usb_controller)I just added "nxp,usb-isp1362" to the compatible string. I think this has to happen otherwise uClinux can't load any driver at all. Btw here is the code snippet from the clkrdy check in isp1362-hcd.c:
/* chip has been reset. First we need to see a clock */
t = jiffies + msecs_to_jiffies(timeout);
while (!clkrdy && time_before_eq(jiffies, t)) {
spin_lock_irqsave(&isp1362_hcd->lock, flags);
clkrdy = isp1362_read_reg16(isp1362_hcd, HCuPINT) & HCuPINT_CLKRDY;
spin_unlock_irqrestore(&isp1362_hcd->lock, flags);
if (!clkrdy)
msleep(4);
isp1362_write_reg16(isp1362_hcd, HCuPINT, HCuPINT_CLKRDY);
if (!clkrdy) {
pr_err("Clock not ready after %lums\n", timeout);
ret = -ENODEV;
return ret;What am I missing here? I guess something is wrong with my device-tree but I checked a lot of entries in your newslist. I don't know what could be wrong here, so any help would be great. For information purpose I attached our sopcinfo file. Thanks in advance. kind regards, Tobias Biehl1 Reply
Hey guys,
my cfi-flash is now working again :) I dont know why flashcp froze my system. I simply made a new kernel-configuration and now it works perfect. I guess I had messed up my config somewhere. Nevertheless accessing the otp-register from my cfi-flash was still causing a kernel-panic, Null Pointer reference in particular. I looked through the code and I stumbled on something. When I'm calling ioctl with OTPSELECT to change the mode, the function otp_select_filemode is called in mtdchar.c. There is a call to another function:
I dont know if its really a bug, but thats the cause of my kernel-panic. the 3rd parameter is len with type size_t. size_t is defined to be __kernel_size_t which is defined as unsigned long. So this would cause an overflow of len. In read_fact_prot_reg() is another call to the function cfi_intelext_otp_walk, which does mostly all the work except the actual read from the otp-register. This does do_otp_read (action points to that function). The code-lines:/* * Make a fake call to mtd_read_fact_prot_reg() to check if OTP * operations are supported. */ if (mtd_read_fact_prot_reg(mtd, -1, -1, &retlen, NULL) == -EOPNOTSUP P) return -EOPNOTSUPP;
well, len is positive, groups will be 1. from is actually -1, so else. And there is a call action() with our buf which is NULL. In there the function tries to copy data to that location -> kernel panic I solved this problem changing the 3rd parameter -1 to 0. I guess this was the idea afterall, that the function just checks if there are otp-register and not trying to read them. Maybe I wrote too much here, but now you guys can easily track down this one, if its really a bug. I guess it is, correct me if I'm wrong =) And my usb is still not working properly, so if anybody knows something there, i would appreciate it. kind regards, Tobias Biehlwhile (len > 0) { /* flash geometry fixup */ data_offset = reg_prot_offset + 1; data_offset *= cfi->interleave * cfi->device_type; reg_prot_offset *= cfi->interleave * cfi->device_type; reg_fact_size *= cfi->interleave; reg_user_size *= cfi->interleave; if (user_regs) { groups = reg_user_groups; groupsize = reg_user_size; /* skip over factory reg area */ groupno = reg_fact_groups; data_offset += reg_fact_groups * reg_fact_size; } else { groups = reg_fact_groups; groupsize = reg_fact_size; groupno = 0; } while (len > 0 && groups > 0) { if (!action) { } else if (from >= groupsize) { from -= groupsize; data_offset += groupsize; } else { int size = groupsize; data_offset += from; size -= from; from = 0; if (size > len) size = len; ret = action(map, chip, data_offset, buf, size, reg_prot_offset, groupno, groupsize); if (ret < 0) return ret; buf += size; len -= size; *retlen += size; data_offset += size; } groupno++; groups--; }
