21 years agoSOPC Builder
ciao to everybody I'm trying to build a new system with cpu nios 2 , sdram ,tristate bridge and my user component I import my component vhdl file and i declare 2 port that in slave are ...
21 years agonow i understand all
Thanks Fisher One question , in your example i saw : # define CONTROL_REGISTER 0# define STATUS_REGISTER 0# define CPU_CLK_DIVIDER 1# define ALARM_TIME_REGISTER 2# define ACTUAL_TIME_REGISTER 3 these are the register the first one in writing mode and reading mode is the control/status register of avalon interfrace . the others ones are in order the register you use in your component. Then in your component analyze wich address and respond or read about your necessity. for example in this case IOWR(AV_CLOCK_0_BASE,CPU_CLK_DIVIDER,50000) the parameters macro's are : AV_CLOCK_0_BASE the address base defined in SOPC Builder CPU_CLK_DIVIDER the offset ralative the address base 50000 the writedata value Avalon bus read the address and multipexs and generate automatically chipselect ... So , if i what to have other register to interface with Avalon bus i must to increase the widht of address in the table in SOPC builder when i import my component and then declare this registers in my component . In your case you declare address widht =2 (00,01,10,11) and the multiplexer cases are 4 The address offset is likes the index "i" in an array that points to exact register i choose. If i declare address widht=3 (000,0010....1111) i can to use 8 register http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Now i like this system and to continue studing . thanks Fisher http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
