13 years agoSending coefficients of degree 1000 from UART to custom logic with Nios II and SOPC.
Hi, I'm pretty new to all this Nios II development and would like to ask advice on the best solution to my project. After receiving coefficients from an UART I have a 2000(GF3 coefficients) cha...
13 years agoOk so unfourtunatly I got a bit lost again.
The plan is to instance the RAM in the SOPC builder or as a megafunction in quartus? Currently I'm trying to understand how the second option would work, if I understood correctly I would implement a Dual-port ram(from the altsyncram megafunction) and from the side of the A-port(from the SOPC system) I would have a 32 bit bus and from the B-port(FSM) I would have a 2000 bit bus. Since I'm new to this I also don't understand how to serialize the output from the SOPC,does the 2000 char table in the nios ii automatically serialize if there is only 32 bits output aviable, or do I have to manually divide the input 2000 char coefficients into 32 bit words diffrent with RAM adresses(so ~62,5 different adresses). Finally, how to connect the SOPC system with the RAM in the first place(PIO?).I attached a simple image to describe how I understood the idea correctly, thanks for any advice you can give. Fred
