21 years agoSDRAM byte (8-bit) write access
Hi all,
I've a NiosII system based on EP1C6144, with an extrernal 2Mb 16-bit wide SDRAM. While writing SDRAM with 16 or 32-bit wide data gives the expected result, if I try to write a single byte (8-bit) I find 2 adiacent bytes written in SDRAM with the same value. To check this behaviour I wrote a simple in-line assembler that make me sure I have not compiling problems: __asm__ ("nop \n\t"
"movi r6, 0x12 \n\t"); // Loads data to be written (0x12) in register R6
__asm__ ("movhi r7, %hi(0x1F7F84) \n\t"
"ori r7, r7, %lo(0x1F7F84) \n\t"); // Loads address data has to be written to (0x1F7F84) in register R7
__asm__ ("stb r6, 0(r7) \n\t"); // Writes BYTE in R6 in address pointed by R7+0
Before these instructions I have the memory window displaying 0x001F7F84 0x00 0x00 0x.... and after instructions... 0x001F7F84 0x12 0x12 0x.... I checked all SDRAM's timing parameters and they seems to be right, in effect code runs from SDRAM and 16 and 32-bit accesses are correct, and also any read access. Any idea? Thanks all, Paolo2 Replies
The one thing which occurs to me is that your code won't work on processors with a cache. You need to use the STBIO instruction instead.
And you should probably use builtin_stbio instead of using inline assembler because the compiler can optimise it much better (or use the HAL macro IOWR_NATIVE8 or something like that which does the same thing). I assume you've checked your objdump file to make sure the compiler hasn't split up your assembler statements (which is will sometimes do to make optimisation better). - Altera_Forum
The processor I use is the "e" version, without any cache...
However I'll try to follow all your suggestions, but I think is an hw problem: I just noticed that UDQM & LDQM signals are wired together to Nios' DQM0... This bring me to think that byte access is not possible on my board... Thank, Paolo
