13 years agoRX and TX UART with NIOS2/e
Hello all, i am beginner in NIOS2 programming and I try to use UART_0 in my system, where i have 22kB RAM on chip. So I have used the hello_world_small template. I tryed to blink with led, setti...
13 years agoPersonally I'd look at the register definition for the UART and write a function to add bytes to the fifo.
You then have to make a concious decision about what to do when the tx fifo is full. Either: - spin waiting for space. - tell caller how many bytes were written (who might ignore the error). You might decide it is worth adding a software fifo, but a large hardware fifo has much the same effect. If you do use a software fifo, you don't necessarily need to use interupts - provided the software can poll the hardware often enough. The same is true of receive - make the hardware fifo big enough. I don't know if the uart can share an internal memory block between its rx and tx sides. It also ought to be possibly to design a multi-port uart that uses a single memory block.
