15 years agoRequired Nios components
Hello, I am trying to develop a very simple Nios cpu to run Hello world application. I have created a design: http://i55.tinypic.com/a29isy.jpg As You can see, I have inserted DDR2 memory ...
15 years ago --- Quote Start --- I'm not sure I understand. Do I use one pipeline_bridge and connect its s0 to both the cpu data_master and instruction_master, then connect the pipeline_bridge m0 to the jtag_debug_module? --- Quote End --- yes only one for data and instruction.......but i agree with Daixiwen ..I'm not sure your problem is related to that if you rise frequence of cpu dont rise the frequence of jtag ......keep jtag uart with same frequence with it works and rise only cpu frequence ... use a clock crossing bridge to do that......... good luck .. Franz Wagner
