13 years agoQ (number format) Multiply
I'm working on a project that uses a 32-bit accumulator, which it's input is a 32-bit step size (unsigned Q30.2) value. The accumulator can rollover when preforming a large number of iterations or w...
13 years agoUrgh. The problem of fixed point using non-fixed point libraries, and the use of non-standard legacy VHDL libraries. (and why o why does everything have to be a std_logic_vector - you can use integers and unsigned and any other type in ports you know)
Anyway, back to code. You are going to overflow big time. If box tr_clk_offset and step_size are 32 bits, the output needs to be 64 bits, not 32., with a Q62.2 output. PS. Have a look into the new fixed point VHDL libraries (Quartus may one day support the real VHDL 2008 files, but until then you can easily use the VHDL93 versions avaiable from www.vhdl.org/fphdl) it allows you to do stuff like this:
signal tr_clk_offset : ufixed(31 downto 0);
signal step_size : ufixed(29 downto -2); --Q30.2
signal amplitude : ufixed(61 downto -2);
amplitude <= tr_clk_offset * step_size;
Look - no hideous type converting (which is what you get when you insist everything has to be a std_logic_vector. Btw, if you decide to use this package, you'll have to forget about using std_logic_unsigned, std_logic_signed and std_logic_arith and use numeric_std instead (which is only a good thing).
