15 years ago
Problem with IRQs. Linux freezing.
Hello i've made a design consisting of a CPU, SDRAM, PHY and etc.
Then i made a character device driver to recieve IRQs from a VHDL block i've made, my VHDL block generates a high signal at a 60hz frequency.
However my Linux freezes after a certain time (like 1minute), why is that?
If i comment the line in my device driver that register the IRQ everything works fine and the linux never freezes!
My device driver implementation is the follow:
Read function:
ssize_t shmem_read(struct file *filep ,char *buff, size_t count, loff_t *offp)
  int retval;
  int temp = 0;
  interruptible_sleep_on(&readw);
  retval = copy_to_user(buff, &current_cycle, sizeof(raw_cycle_t));
  if (retval != 0) {
    printk(KERN_ERR "Kernel to userspace copy failed!\n" );
    return retval;
  return count;
IRQ handler
static irqreturn_t io_irq_handler(int irq, void *dev_id)
  wake_up_interruptible(&readw);
  outl(0xf, &pio_in->np_pioedgecapture);
  return IRQ_HANDLED;
INIT_IRQ
 /* IRQ PIO INPUT INIT */
  io_irq = PIO_IRQ;
  enable_irq(io_irq);
  ret = request_irq(io_irq, &io_irq_handler, 0, DRIVER_NAME, &io_irq);
  if (ret) {
    printk(KERN_ERR __FILE__ ": Error while requesting IRQ, during %s\n", __FUNCTION__);
    return ret;
    I guess i was having a deadlock.. when i run it with realtime process priority i have no problems.
    EDIT:
    NVM just had the same problem after a longer time..
    I changed my PIO irq from Level to Edge and everything works fine
