15 years agoProblem with GRAPHICS LCD Interface (128*64) for cyclone 3c120 device
Hi all,
I'm a novice programmer to interface graphics LCD (glcd) using cyclone iii 3c120 device. The display is an Optrex part number F-51852GNFQJ-LB-CAN (Green Pixels). 128 × 64 dot matrix graphics LCD display. I'm using Nios II Eclipse IDE to interface glcd with a C language based API. The C source file is shown below(taken from 24931 post id): # include<stdio.h># include <unistd.h># include "system.h"# include "altera_avalon_pio_regs.h" void glcd_writeByte(int DI, int data) { if (DI == 1) { IOWR_ALTERA_AVALON_PIO_DATA(GLCD_D_CN_BASE, 0x01); //write a command; } else { IOWR_ALTERA_AVALON_PIO_DATA(GLCD_D_CN_BASE, 0x00); //write data; } IOWR_ALTERA_AVALON_PIO_DATA(GLCD_DATA_BASE, data); //put DATA on the data lines; usleep(2); //wait 2 us IOWR_ALTERA_AVALON_PIO_DATA(GLCD_WEN_BASE, 0x00); //pull the Write Enable pin low to enable writing to the LCD usleep(2); //wait 2 us IOWR_ALTERA_AVALON_PIO_DATA(GLCD_WEN_BASE, 0x01); //pull the ENABLE pin high to disable writing to the LCD } void glcd_init(void) { IOWR_ALTERA_AVALON_PIO_DATA(GLCD_WEN_BASE, 0x01); IOWR_ALTERA_AVALON_PIO_DATA(GLCD_D_CN_BASE, 0x01); IOWR_ALTERA_AVALON_PIO_DATA(GLCD_RSTN_BASE, 0x00); // Hard reset usleep(20); // Wait 20us; IOWR_ALTERA_AVALON_PIO_DATA(GLCD_RSTN_BASE, 0x01); // Release reset; usleep(100000); // Wait 100ms); glcd_writeByte(0, 0xe2); // Internal Reset glcd_writeByte(0, 0xa2); // Bias = 1/9; 0xa3 for 1/7 glcd_writeByte(0, 0xa1); // ADC = 1 (right to left); 0xa0 for 0(left to right) glcd_writeByte(0, 0xc0); // Common direction = Normal; 0xc1 for inverse glcd_writeByte(0, 0x28); // Set Power Control - Internal power circuits OFF ******* but looks better with 0x2f glcd_writeByte(0, 0xe7); // Set Driver ON; 0xe6 for OFF glcd_writeByte(0, 0xaf); // Display ON; 0xae for OFF glcd_writeByte(0, 0xa5); // Entire Display ON - Turn ON all pixels (irrespective of RAM) usleep(500000); // Wait 500ms glcd_writeByte(0, 0xa4); // Entire Display NORMAL - Pixels correspond to display RAM } int main(void) { printf("Graphics LCD Display\n"); glcd_init(); } ********************************************* GLCD Pin Specs: ---------------- LCD_DATA0: AA4 LCD_DATA1: AD1 LCD_DATA2: V8 LCD_DATA3: AB5 LCD_DATA4: AE2 LCD_DATA5: V5 LCD_DATA6: V6 LCD_DATA7: AB3 LCD_BS1: ??? Parallel Interface Selection* LCD_CSn: AB24 LCD_D_Cn: D27 LCD_E_RDn: V7 LCD_RSTn: H7 LCD_WEn: AC4 LCD_SERn: ??? LCD Parallel/Serial DATA Select* ********************************************* My SOPC system contains the following components:- NIOS II Processor
- ON-Chip Memory 256Kb
- JTAG UART
- LCD_DATA
- LCD_CSn (1-bit PIO)
- LCD_D_Cn (1-bit PIO)
- LCD_E_RDn (1-bit PIO)
- LCD_RSTn (1-bit PIO)
- LCD_WEn (1-bit PIO)
- LCD_BS1
- LCD_SERn
TO_BE_DONE
--- Quote Start --- After run this code, your GLCD will display ALTERA logo. Any problem u can contact with me. --- Quote End --- Hi, I made all the steps described in this thread but my glcd still doesn't display anything. I know i'm doing something wrong but i don't know what it is. I used your NIOS program and also used the system described by samratv with that pin assignment. I have the F-51852GNFQJ-LB-AIN (Blue pixels), is that why it doesn't work for me?? Thnxs
