13 years agoPCIe "Enumeration" SW on NIOS II ?
Hi All, Does anyone know where I can get PCIe Enumeration program (written in 'C') to run on NIOS II ? I have the Stratix IV dev. board, configured as RooPort, plugged into a chassis with a ...
13 years ago --- Quote Start --- OK, my design has a NIOS II based SOC and a PCIe Altera IP in the top-level. The NIOS II and all peripherals run on 100Mhz but interface via MM-FIFOs at 50Mhz to the PCIe IP. I have a simple utility programs that sends config. packets to the PCIe IP and it replies correctly with device ID, etc. The card is plugged in a system slot on the bus AND it provides the PCIe clock to the bus. I took over the design from someone else... so I am not sure really what differentiate a RootPort from an EndPoint other than who provides the 100Mhz clock. I did not know that an EndPoint can do enumeration. --- Quote End --- You took over the design from someone else, so first you need to understand it. If you can answer my questions, then you'll be a little further along in understanding the design you have inherited. Can you post a link to the motherboard or backplane that you are plugging the board into. As I commented above, the Stratix IV Development Board is a PCIe peripheral board, so it only makes sense that it gets configured as a PCIe end-point. When your test system powers on, the root-complex (typically a PC) writes to configuration space to tell each of the PCIe-to-PCIe bridges what their address ranges are, and writes to PCIe peripherals to tell them what their PCIe addresses are. If your root-complex (host) was running Linux, you could type lspci and see the addresses that the BIOS assigned to the PCIe bridges and peripheral boards. You comment that --- Quote Start --- I have a simple utility programs that sends config. packets to the PCIe IP and it replies correctly with device ID, etc. --- Quote End --- Where is this program running? On a NIOS II processor inside an FPGA on the Stratix IV kit, or on the host PC? Cheers, Dave
