13 years agoPCIe "Enumeration" SW on NIOS II ?
Hi All, Does anyone know where I can get PCIe Enumeration program (written in 'C') to run on NIOS II ? I have the Stratix IV dev. board, configured as RooPort, plugged into a chassis with a ...
13 years ago --- Quote Start --- The 100Mhz is only on the NIOS II Avalon bus, the PCIe Avalon-MM- FIFOs have 100Mhz on one side and 50Mhz on the PCIe side. --- Quote End --- You state that you've created a PCIe "root complex" device. However, I believe this only makes sense if you are in the "system" slot of the bus. If you are in a peripheral slot, you would configure the PCIe as an "end-point". An end-point can still enumerate the PCIe bus, but it has a 100MHz input clock as a reference. --- Quote Start --- I can send config. packets to the PCIe IP and it responds correctly. --- Quote End --- Sending from what? Your NIOS processing inside the FPGA, or another peripheral in your motherboard? --- Quote Start --- Can you tell me more about "building UBoot for NIOS II" ? (I am a HW guy...) We don't intend to use Linux for now. --- Quote End --- Sorry, I haven't used it. Create a new thread with a new title and someone else can probably help. Cheers, Dave
