15 years agonon-cacheable instruction memory
Hi at all, I'm new in this forum. I create a Nios II system containing a Nios II/f core, with 2k data cache and 2k instruction cache, and 128k of on chip-memory. I want to run on this system an ...
15 years agoI solved the problem using the section .ddr_sdram_0 (name of section corresponding to my on-chip memory) to load the cacheable part of the code.
The instruction is: .section .ddr_sdram_0 inserted before the part of code to load on that memory. Now observing the content of my .elf file the instructions corresponding to cacheable and not cacheable parts of my code are loaded at correct addresses. But when I debug the code on my board, when the code jumps to cacheable part there aren't the same instructions listed in .elf file. At the same address the .elf file contains a different instruction compared to the disassembly of the debugging code. What does it means?:confused::confused::confused::confused: Thank you. Rolfo Daniele
