15 years agonios2-mmu linux stuck on #Switching to clocksource timer#?
hello, With socrates (http://www.alteraforum.com/forum/member.php?u=7474)'s tips, I soved the memory problem, but it still stuck, see the result:
Linux version 3.1.0-rc4-01162-g45c9dd8-dirty ...
14 years agoFound the issue (obvious in hindsight):
The exception vector hardcoded in the NIOS core was pointing to the EPCS Flash memory, because I was thinking that for each exception, I wanted to restart the processor. However, since interrupts are handled as exceptions through the internal interrupt controller, I was jumping to an address in the EPCS and hanging. Once I changed the exception vector to be the 0x20 offset into my main instruction memory, my problem went away, since the correct ISR was being called.
