14 years agoNIOS II PIO Data read problem
Hi All.
I have some problems with data processing, based on NIOS core. My FPGA project includes external interface, strobe line (NIOS Internal interrupt or just Flag), 8 bit data input port and FIFOed UART (as stdout). I try to read PIO data from Port, but i see that they are wrong (I have ana another external UART for Debug, included before the NIOS Port). I have no Idea, what is wrong. Please, tell me... Source code: while(1) { do { edge = IORD_ALTERA_AVALON_PIO_DATA(STROBE_BASE); IOWR_ALTERA_AVALON_PIO_EDGE_CAP(STROBE_BASE, 0x0); } while(edge & 1); data = IORD_ALTERA_AVALON_PIO_DATA(DATA_BASE); printf("0x%02X ",data); IOWR_ALTERA_AVALON_PIO_EDGE_CAP(DATA_BASE, 0x0); do { edge = IORD_ALTERA_AVALON_PIO_DATA(STROBE_BASE); IOWR_ALTERA_AVALON_PIO_EDGE_CAP(STROBE_BASE, 0x0); } while((edge & 1) == 0); } Thank you...3 Replies
First of all you must write ones, not zero, into edge capture register to reset status:
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(STROBE_BASE, 1) Anyway this seems to be irrelevant, unless you are using edge capture in another part of the code. I guess your problem is that you can't get the correct pio status in 'data', isn't it? This can be simply due to bad timing relative to strobe signal. - Altera_Forum
Yes it is. I can not get a correct data from PIO port inside NIOS core. I have an idea about wrong external timing signal for STROBE input. In addition, it seems to me, that i can sometimes read data at the same time that as they are changes. Can i use triggered buffer for this data?
I don't know the timing of your signals, but if you are really getting data when it is changing, I think you should read it after the second while loop or maybe read after a short delay.
If you can change the 'hardware' part (I mean fpga design) besides Nios software, I suggest you add a bit of glue logic in order to latch your pio data when the strobe signal becomes active. In other words you make the same as those while loops but in a more efficient and stable way, at the expense of using a few more fpga resources.
