PHJ's avatar
PHJ
8 years ago
mkimage for Windows
I'm following the instructions in ​Intel® Arria® 10 SoC UEFI Boot Loader User Guide for getting the QSPI UEFI boot loader working.
It has steps to run a tool called mkimage.
Where do I find a windows version of this tool ?
  • Hi,
    As a workaround you can install Standard Version of SoC EDS and copy the "mkimage" directory to Pro SoC EDS install directory.
    Let me know if you are able to proceed with this.
    Arslan
  • Hi,
    Arslan
  • PHJ's avatar
    PHJ
    Thanks Arslan - this has worked for me.....​
  • Hi,
    You need to launch SoC EDS command shell to use "mkimage" command in windows.
    Arslan
  • PHJ's avatar
    PHJ
    Thanks MUsman - however this does not work for me - is it meant to be part of the Quartus 18.0 distribution ?
    I just get:
    ​$ mkimage
    bash: mkimage: command not found
  • PHJ's avatar
    PHJ
    Hi Arslan -
    I installed SoCEDSProSetup-18.0.0.219 when I first got the A10 dev kit.
    Should this have included the mkimage tool - if so, where is it installed ?
    I can run the SoC EDS command shell no problem - it is just mkimage that I cannot find.
    Thanks !​
  • I attached a screenshot for SoC EDS command shell, using Quartus Standard 17.1
    Can you share your screenshot ?
  • PHJ's avatar
    PHJ
    It looks like I have something missing from my install - I have no mkimage folder in embedded\host_tools\altera....
  • PHJ's avatar
    PHJ
    With the new mkimage, I still could not get the instructions from ​Intel® Arria® 10 SoC UEFI Boot Loader User Guide to work correctly.
    I tried the following steps:
    $ mkimage -A arm -T firmware -C none -O u-boot -a 0 -e 0 -n "RBF" -d
    ghrd_10as066n2.rbf ghrd_10as066n2.rbf.mkimage
    $ quartus_hps -c1 -oP --addr=0x00720000 ghrd_10as066n2.rbf.mkimage
    The boot code reported:
    Programmed RBF is not peripheral
    The length of the RBF was ~15MB and therefore failed the check against the max 512k size.
    I've tried doing the following to program the periph and core RBFs separately and this has got me past this error:
    $ mkimage -A arm -T firmware -C none -O u-boot -a 0 -e 0 -n "RBF" -d output_files/ghrd_10as066n2.periph.rbf ghrd_10as06
    6n2.periph.rbf.mkimage
    $ quartus_hps -c1 -oP --addr=0x00720000 ghrd_10as066n2.periph.rbf.mkimage
    $ mkimage -A arm -T firmware -C none -O u-boot -a 0 -e 0 -n "RBF" -d output_files/ghrd_10as066n2.core.rbf ghrd_10as066n
    2.core.rbf.mkimage
    $ quartus_hps -c1 -oP --addr=0x00820000 ghrd_10as066n2.core.rbf.mkimage
    Does this look correct ?
    Is this related to the version of mkimage, or are the instructions in the doc wrong ?
  • PHJ's avatar
    PHJ
    Have read back and I guess that the instructions are assuming Automatically Loaded Combined RBF
