max10 remote system update nios with uart
hii when i compile this project i get errors due to licince issues how can i solve it ?
Hello
Nios II is EOL, Altera stop selling Nios II/f license.
New users need to migrate to Nios V and apply the Nios V license.
Regarding the example design, couple of points below that can help you.
To simplify the design, it can be divided into three function blocks:
- RSU block (Dual Configuration IP to handle RSU)
- UART block (Communication thru UART)
- Booting block (Nios to boot from QSPI)
UART block (Communication thru UART, such as printf & scanf)
Booting block (Nios booting from QSPI)
Below User Guides will help you to understand more about these function blocks.
- MAX® 10 FPGA Configuration User Guide (How does Dual Configuration IP handle Max 10 RSU?)
- MAX® 10 User Flash Memory User Guide (Dual Configuration IP switches the target CFM only, you will need On-Chip Flash IP to change the FPGA Image in CFM)
- UART Core (Altera HAL driver to send/receive UART data in Software Programming Model subchapter)
- Nios® II Processor Booting from QSPI Flash (QSPI Controller + OCRAM is a must to boot Nios II from QSPI)
- Nios® V Processor Booting from General Purpose QSPI Flash (QSPI Controller + OCRAM is a must to boot Nios V from QSPI)
And finally connecting the 3 logic blocks to get the whole design,
- aiedb1 year ago
hii thanks a lot for reply that helped me alot
now i understand what is the problem - Sparrow_Altera1 year ago
That's great, glad that helped.
- aiedb1 year ago
hii
do you have a design guide that explains how to do RSU without the need of a nios 2 processor
lets say i want to write my own vhdl code to perform the rsu , from what i understand
1- i need to be able to read and write the cfm sections in order to write the my image into cfm0 and cfm1/2 in dual compressed mode
2- trigger the fpga in order to read the new image from cfm1/2 and configure the fpga logic by hardware or software
i would like to know if there an application note that explains how to do RSU manually without the help of nios
3- another question if i configure the nios v processor to boot from qspi does it take up from the logic elements ?
- SueC_Altera1 year ago
Contributor
Hi Aiedb,
It is helpful to start a new thread for new questions.
I hope you have read the Max10 configuration user guide - it has a detailed RSU section.
Sue
Hello
Please open a new thread for this item as this is a new topic.
