20 years ago
LwIP doens't work with NIOS II 6.0
Hi all,
I&#39;ve a Standalone LwIP project (download from topic "Tested IP") with NIOS II & QUARTUS 5.1. I&#39;ve been testing this project with NIOS II & QUARTUS 6.0 and i&#39;ve got a lot of problems and I couldn&#39;t build my project. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
It&#39;s related with LAN91C111 code, that can&#39;t be reached.
I couldn&#39;t solve this problem, but if someone got it, please answer this topic. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif
Next, the errors I founded.
Nosima
**** Incremental build of configuration Debug for project lwip_web_server_0 ****
make -s all
Compiling echo.c...
Compiling fs.c...
Compiling fsdata.c...
Compiling httpd.c...
Compiling dhcp.c...
../lwip-0.7.1/src/core/dhcp.c:1395: warning: &#39;dhcp_get_option_short&#39; defined but not used
Compiling inet.c...
Compiling icmp.c...
Compiling ip.c...
Compiling ip_addr.c...
Compiling ip_frag.c...
Compiling mem.c...
Compiling memp.c...
Compiling netif.c...
Compiling pbuf.c...
Compiling raw.c...
Compiling stats.c...
Compiling sys.c...
Compiling tcp.c...
Compiling tcp_in.c...
Compiling tcp_out.c...
Compiling udp.c...
Compiling etharp.c...
Compiling loopif.c...
../lwip-0.7.1/src/netif/loopif.c:48: warning: &#39;loopif_input&#39; defined but not used
Compiling lib.c...
Compiling lwip_init.c...
Compiling lan91c111if.c...
../lwip4hal/netif/lan91c111if.c: In function `low_level_output&#39;:
../lwip4hal/netif/lan91c111if.c:76: error: `alt_avalon_lan91c111_if&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:76: error: (Each undeclared identifier is reported only once
../lwip4hal/netif/lan91c111if.c:76: error: for each function it appears in.)
../lwip4hal/netif/lan91c111if.c:76: error: `dev&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c: In function `low_level_input&#39;:
../lwip4hal/netif/lan91c111if.c:185: error: `alt_avalon_lan91c111_if&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:185: error: `dev&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:194: warning: use of cast expressions as lvalues is deprecated
../lwip4hal/netif/lan91c111if.c: In function `lan91c111if_service&#39;:
../lwip4hal/netif/lan91c111if.c:276: error: `alt_avalon_lan91c111_if&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:276: error: `dev&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:276: error: parse error before &#39;)&#39; token
../lwip4hal/netif/lan91c111if.c: In function `low_level_init&#39;:
../lwip4hal/netif/lan91c111if.c:303: error: `alt_avalon_lan91c111_if&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:303: error: `dev&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:303: error: parse error before &#39;)&#39; token
../lwip4hal/netif/lan91c111if.c:311: warning: implicit declaration of function `read_mac_address&#39;
make: *** [obj/lwip4hal/netif/lan91c111if.o] Error 1
Build completed
