21 years agoLow Level IO
Hi
I'm using Microtronix uClinux ver 2.6 for NiosII I am trying to utilize the low level IO functions inb, outb etc in one of my apps. to read / write my hardware devices but I cannot build my project without getting "implicit declaration of inb..." etc. warnings How do I access these IO functions from within user space in uClinux? Is there a user level io.h somewhere or can I set a compiler flag to access the kernel level functions??? Nick1 Reply
Hi nipri,
inb(), outb(), etc. are defined in asm/io.h ... but they're normally wrapped with an# ifdef __KERNEL__ ... this means they're intended for use by the kernel itself (or loadable modules) ... pulling them into user-space apps is not recommended. A device driver is where this type of hardware access is typically implemented. That said, you can just define your own macros ... hoist them from the kernel sources (or u-boot) into your app's source tree as they're normally just a set of macros (see below) ... without an MMU, uClinux won't care. Regards, --Scott#define readb(addr) ({unsigned char val; asm volatile( "ldbio %0, 0(%1)" :"=r"(val) : "r" (addr)); val;}) # define readw(addr) ({unsigned short val; asm volatile( "ldhio %0, 0(%1)" :"=r"(val) : "r" (addr)); val;}) # define readl(addr) ({unsigned long val; asm volatile( "ldwio %0, 0(%1)" :"=r"(val) : "r" (addr)); val;}) # define writeb(addr,val) asm volatile ("stbio %0, 0(%1)" : : "r" (addr), "r" (val)) # define writew(addr,val) asm volatile ("sthio %0, 0(%1)" : : "r" (addr), "r" (val)) # define writel(addr,val) asm volatile ("stwio %0, 0(%1)" : : "r" (addr), "r" (val)) # define inb(addr) readb(addr)# define inw(addr) readw(addr)# define inl(addr) readl(addr)# define outb(addr,val) writeb(addr,val)# define outw(addr,val) writew(addr,val)# define outl(addr,val) writel(addr,val)
