21 years agolocking the mutex
Whats wrong with my code?? My system is running with two cpu's. To get started with the different commands I'm just testing with a Hello World app:int main()
char *test;
test = mutex_uart1_name;
int i = 0;
while(1)
if (altera_avalon_mutex_trylock(&test, 16) == 0)
printf("cpu 1: int = %i. hello from nios ii!\n", i);
altera_avalon_mutex_unlock(&test);
i++;
usleep(2000000);
return 0;
The application is running on both cpu's, but even though the trylock returns 0 (=mutex lock ok), the other cpu's also get to lock the mutex, or, i guess, none of them do..... I also wonder why this code is not working (skipping the test-pointer):
int main()
int i = 0;
while(1)
if (altera_avalon_mutex_trylock(mutex_uart1_name, 0) == 0)
printf("cpu 2: int = %i. hello from nios ii!\n", i);
altera_avalon_mutex_unlock(mutex_uart1_name);
i++;
usleep(2000000);
return 0;
} Stian
problem solved with the mutex_open() handler...
I also have the same scenario, but when I program and start my first core it works. As I program and start the second core, it freezes the first code. These happen only when i implement the mutex for sharing some common address space between two cores. Otherwise if I run two cores independently, it RUNs. Please suggest.
