13 years agoIssue with the application layer from NIOS II IDE while accessing a custom instructio
Hello, I have implemented a custom instruction for full adder (just a basic one) in verilog for NIOS II. However when my application code (C) from NIOS II tries to access the macro for the cu...
13 years agoHello,
Sorry, it had been my fault in the verilog and the fault was with respect to the timing. Earlier, I had been trying to do the ADD operation and read the result output port in the same clock cycle which was making the module confused and I guess the dataa port had been getting unknown value (like 2047) because of that timing issue. I really appreciate for BadOmen who made me to look into the custom instruction timing diagram once again (I am just a beginner). See what I did now is having separate 'write' and 'read' instructions and added the lines of code in verilog module custom_Component.v if(write && chipselect) begin cin = 0; {cout, output_value} = writedataa + writedatab + cin; end else if((read == 1) && (chipselect == 1)) begin readdata <= output_value; end so that before reading a result port, there will be a write latency. I tried to access from the application code (in NIOS II IDE) like this: /* Write Sum */ dataa = 0XFFFFFFFF; datab = 0XFFFFFFFF; sumOutput = ALT_CI_CUSTOM_ADD_INST(1,dataa,datab); printf("\nThe result line value is %lu",sumOutput); // Expect some unknown value to print /* Read Sum */ sumOutput = ALT_CI_CUSTOM_ADD_INST(4,dataa,datab); // Expect the earlier SUM value to print printf("\nThe SUM of %lu and %lu is %lu",dataa,datab,sumOutput); And the sumOutput variable printed an expected value!. I appreciate the effort taken by forum admins to sort this out. Thank You, Akhil
