14 years ago
How to read RS232 ?
Hello all,
I have problem with UART, when i want to read serial data (hex byte message - something like bytes: 02,05,01,02,05 after this 10ms space and 03,05,xx,yy,zz etc.).
I have development kit DK-DSP-EP2S60 and when i connect the board, which send me bytes to the NIOS2 design with uart and in uClinux i use:
fd = open(S0_232, O_RDWR | O_NDELAY | O_NONBLOCK );
fd = open(S0_232, O_RDONLY | O_NOCTTY | O_NDELAY );
and when the program perform this command, the data from RxD RS232 are sended to the output TxD. I dont understand why ? (why it create loopback on RS232)
How is possible to read data from RS232 without loopback ? (how to set RS232 for reading only ?)
Thank you very much.
Jan Naceradsky, Czech Republic
    I forgot:
    SO_232 is device "/dev/ttyS0"
    # define S0_232 "/dev/ttyS0"
    Jan Naceradsky
    Because the linux driver will be assuming you want tty semantics.
    You need to change the tty mode - see 'man termios' (at a guess).
    Thank you.
    I finally solved it with my collegue which advice me to add command
    stty -F /dev/ttyS3 sane -echo -icanon
    to rc file. This command stop the echo of input characters.
    And after open command in program i use:
    void init_rs232(void)
    struct termios options;
    fd = open(S0_232, O_RDWR | O_NOCTTY | O_NDELAY );
    if (fd > 0)
    { fcntl(fd, F_SETFL, O_NONBLOCK);
    tcgetattr(fd, &options);
    options.c_cflag |= (CLOCAL | CREAD | CS8 );
    options.c_cc[VMIN] = 1;
    options.c_cc[VTIME] = 0;
    options.c_lflag = FLUSHO;
    tcsetattr(fd, TCSANOW, &options);
    printf("Init RS232 OK.\n");
    and now it works well.
    Jan Naceradsky
    The 'stty' comand probably does nothing useful - I'm not even sure the values persist once the device is closed.
    You are already disabling echo and icanon when you set c_lflag.
    Yes, you are right, i cancel stty command in linux and use
    options.c_lflag &= ~(ICANON | ECHO | ISIG );
    in open function:
    // fd = open(S0_232, O_RDWR); // | O_NOCTTY | O_NDELAY );
    if (fd > 0)
    fcntl(fd, F_SETFL, FNDELAY);
    options.c_cflag |= (CLOCAL | CREAD );
    options.c_cflag &= ~PARENB; // set no parity, stop bits, data bits
    options.c_cflag &= ~CSTOPB;
    options.c_cflag &= ~CSIZE;
    options.c_cflag |= CS8;
    But when i read hex message (from PC to Altera NIOS2 system)
    16,11,01,00,00,00,00,80,00,7B
    the linux read
    16,01,00,00,00,00,80,00,7B
    and the second byte doesn't receive .... i read the termios on:
    http://slackware.osuosl.org/slackware-3.3/docs/mini/serial-port-programming
    and they say that 0x11 is DC1 which mean VSTART for XON and XOFF and i am not able to disable this software flow control.
    When i use setting
    options.c_cflag &= ~(IXON | IXOFF | IXANY); // no flow control
    or
    options.c_cflag &= ~CRTSCTS;
    it doesnt work. Read again:16,01,00,00,00,00,80,00,7B (and the 0x11 is missing).
    Do you have somebody program, which can read EVERY characters (hex - 00-FF) without any control meanings ?
    Is possible to disable control characters in options.c_cc[xxx] ?
    I retype
    options.c_cc[VSTART] = 0xFE;
    and the message is read ok, but echo was set ... why ?
    Where is error ?
    Jan, Czech Republic
    Are you actually certain the PC is sending the 0x11 byte ?
