14 years agoHow to provide different clock for PHY Device
My board DE2-115 My PHY Device:88E1111 My project is about simple socket server.Now I can send words or command via Telnet or Ping, when I use a router(100Mbps). But, when I directly connec...
14 years ago --- Quote Start --- Use example projects and search for file mii_gmii_mux.vhd. Or You can write Your own clock mux. --- Quote End --- Dear Socrates, thanks for your reply. I find the file GMII_MII_MUX.v But I still don't know how to change these codes.They are as follows: ******************************************************** module GMII_MII_MUX ( //--- PHY Interface reset_rx_clk_n, phy_rx_clk, phy_rx_col, phy_rx_crs, phy_rx_d, phy_rx_dv, phy_rx_err, reset_tx_clk_n, tx_clk_ref125, // 125MHz TX local reference clock tx_clk_phy125, // 125MHz TX clock for GMII tx_clk_mac, // TX clock to use by the MAC tx_clk, // 25MHz/2.5MHz TX clock from PHY, phy_gtx_clk, // TX clock to PHY phy_tx_d, phy_tx_en, phy_tx_err, phy_mdio, //--- Local MII Interface m_rx_col, m_rx_crs, m_rx_d, m_rx_dv, m_rx_err, m_tx_d, m_tx_en, m_tx_err, //--- Local GMII Interface gm_rx_d, gm_rx_dv, gm_rx_err, gm_tx_d, gm_tx_en, gm_tx_err, //--- eth_mode, //--- Mode select, from MAC configuration, 1 : Gigabit, 0 : 10/100 ena_10, mdio_in, mdio_oen, mdio_out ); //========================================================= // PARAMETER declarations //========================================================= //========================================================= // PORT declarations //========================================================= //--- PHY Interface input reset_rx_clk_n; input phy_rx_clk; input phy_rx_col; input phy_rx_crs; input [7:0] phy_rx_d; input phy_rx_dv; input phy_rx_err; input reset_tx_clk_n; input tx_clk_ref125; input tx_clk_phy125; output tx_clk_mac; input tx_clk; output phy_gtx_clk; output [7:0] phy_tx_d; output phy_tx_en; output phy_tx_err; inout phy_mdio; //--- Local MII Interface output m_rx_col; output m_rx_crs; output [3:0] m_rx_d; output m_rx_dv; output m_rx_err; input [3:0] m_tx_d; input m_tx_en; input m_tx_err; //--- Local GMII Interface output [7:0] gm_rx_d; output gm_rx_dv; output gm_rx_err; input [7:0] gm_tx_d; input gm_tx_en; input gm_tx_err; //--- input eth_mode; input ena_10; output mdio_in; input mdio_oen; input mdio_out; //========================================================= // REG/WIRE declarations //========================================================= wire tx_clk_int; reg mode_reg1; reg mode_reg2; reg [7:0] gm_rx_d_r; reg gm_rx_dv_r; reg gm_rx_err_r; reg gtx_clk; //========================================================= // Structural coding //========================================================= // mdio tristate assign mdio_in = phy_mdio; assign phy_mdio = mdio_oen ? 1'bz : mdio_out; // PHY RX input always @(negedge reset_rx_clk_n or posedge phy_rx_clk) begin if (reset_rx_clk_n == 1'b0) begin gm_rx_d_r <= 8'b00000000; gm_rx_dv_r <= 1'b0; gm_rx_err_r <= 1'b0; end else begin gm_rx_d_r <= phy_rx_d; gm_rx_dv_r <= phy_rx_dv; gm_rx_err_r <= phy_rx_err; end end // MII RX local interface assign m_rx_col = phy_rx_col; assign m_rx_crs = phy_rx_crs; assign m_rx_d = gm_rx_d_r[3:0]; assign m_rx_dv = gm_rx_dv_r; assign m_rx_err = gm_rx_err_r; // MII RX local interface assign gm_rx_d = gm_rx_d_r[7:0]; assign gm_rx_dv = gm_rx_dv_r; assign gm_rx_err = gm_rx_err_r; // TX clock MUX always @(negedge reset_tx_clk_n or posedge tx_clk_ref125) begin if (reset_tx_clk_n == 1'b0) begin mode_reg1 <= 1'b0; mode_reg2 <= 1'b0; end else begin mode_reg1 <= eth_mode; mode_reg2 <= mode_reg1; end end assign tx_clk_int = mode_reg2 ? tx_clk_ref125 : tx_clk; assign tx_clk_mac = tx_clk_int; assign phy_tx_d = mode_reg2 ? gm_tx_d : {4'b0000,m_tx_d[3:0]}; assign phy_tx_en = mode_reg2 ? gm_tx_en : m_tx_en; assign phy_tx_err = mode_reg2 ? gm_tx_err : m_tx_err; // GXT_CLk driver ddr_o gen_gxt_clk ( .datain_h(1'b1), .datain_l(1'b0), .outclock(tx_clk_phy125), .dataout(phy_gtx_clk) ); endmodule ******************************************************** Can you tell me what should I do to get 125MHz for PHY Device and then enable the 1000Mbps? Have a good day,Socrates.
