22 years agoHow to increase DMA fifo depth?
I need to increase the depth of the fifo in an Avalon dma. I thought I remembered reading about it, but I can't seem to find anything that jumps out at me in the .ptf. (dma v3.1, Nios v3.2) ...
22 years agoThanks Koma,
I should update this thread with the latest. Raising the fifo depth helps a bit, but there is a problem in that the dma reads do not heed the FIFO_FULL flag and so anytime your Avalon bus gets busy during a dma it can corrupt the data. I have submitted this as a bug to Altera and hope it will be fixed very soon. I looked through the dma HDL to see if it would be simple to qualify the reads with !FIFO_FULL, but I'm afraid my HDL skills are nil. I think Altera must have known something was up as the nr_dma_* functions all loop until the dma is complete - thus turning the dma into a synchronous memcpy. So if you're expecting true dma behavior you'll have to modify the dma calls. I looked through the NiosII/HAL dma code and it appears to function correctly. Anyone useing dma's should run a lot of test data through the system under heavy load and check for errors. Setting a SignalTap trigger on the dma's FIFO_FULL is also a good idea. Ken
