16 years agoHow the avalon mm slave "address alignment" works?
Hi everyone I use avalon mm slave port with conduit to interface a 16bits peripheral, but everytime when i READ the peripgheral, the data readback can not in correct address when inspected in...
16 years agodid u already solved that problem ???
i m just trying to read from my own HDL but i dunno exactly how to use the adress i got more than 1 parameter where i would like to read/write from/to i m using the IORD_32DIRECT and IOWR_32DIRECT but the controll over the address don t work dunno why -.- sometimes it makes one thing sometimes not. at the moment i can read from RGB_ADDR but nothing else and i can write to GRAY and THREST but not to SCREENSHOT -.- before i had played a bit on the addresses i could set SCREENSHOT but couldn t read or write anything else ... HELP MEEEEE plz heres an example: NIOS II CODE:#define RGB_ADDR (0x01)# define SCREENSHOT (0x02)# define GRAY (0x03)# define THRESH (0x04)# define READOBJEKTX (0x08)# define READOBJEKTY (0x05)# define STARTFOUND (0x06)# define START (0x07)
IOWR_32DIRECT(PICREADANDFIND_0_BASE,SCREENSHOT,0x00000001);
IOWR_32DIRECT(PICREADANDFIND_0_BASE,GRAY,0x00000001);
IOWR_32DIRECT(PICREADANDFIND_0_BASE,THRESH,0x00000001);
start_found=IORD_32DIRECT(PICREADANDFIND_0_BASE,STARTFOUND);
I_XYBILD = IORD_32DIRECT(PICREADANDFIND_0_BASE,RGB_ADDR); and the Code in Verilog: module(
MYADDR,
MYWRITEDATA,
MYREADDATA,
MYWRITE,
MYREAD
input MYADDR;
input MYWRITEDATA;
input MYWRITE;
input MYREAD;
output reg MYREADDATA;
parameter RGB_ADDR = 8'h01;
parameter SCREENSHOT = 8'h02;
parameter GRAY = 8'h03;
parameter THRESH = 8'h04;
parameter READOBJEKTY = 8'h05;
parameter STARTFOUND = 8'h06;
parameter START = 8'h07;
parameter READOBJEKTX = 8'h08;
always@ (posedge CLK50)
begin : AVALON_INTERFACE
begin
if(MYWRITE == 1'b1)
begin
case(MYADDR)
SCREENSHOT : screenshotreg <= MYWRITEDATA;
STARTFOUND: getStart <= MYWRITEDATA;
GRAY: Grayreg <= MYWRITEDATA;
THRESH: Threshreg <= MYWRITEDATA;
default:;
endcase
end
else if((MYREAD == 1'b1) )
begin
case(MYADDR)
RGB_ADDR:
begin
MYREADDATA <= {xstart};
end
READOBJEKTX:
begin
end
READOBJEKTY:
begin
MYREADDATA <= {32'hFFF11FFF};
screenshotreg <= ~screenshotreg;
end
STARTFOUND:
begin
MYREADDATA <={31'h00,set_start};
end
default: MYREADDATA <= 32'hFFFAAFFF;
endcase
end
endmodule
