22 years ago"FIFO Interface" component support
Here's the place to talk about the FIFO interface component that I just posted. Fire away!
22 years ago --- Quote Start --- originally posted by kenland+aug 2 2004, 04:48 pm--><div class='quotetop'>quote (kenland @ aug 2 2004, 04:48 pm)</div>
--- quote start ---
i haven't installed your ip yet, but after reading your post i had the silly question of how is your component better than just using a lpm_fifo?
i'm not saying it isn't, i'm just wanting to learn. i hooked up an lpm_fifo with iul and irq on almost_full, and want to know what that approach lacks. it seemed to work pretty well.[/b]
--- quote end ---
hahaha... now that you mention it, an iul instance would cover about half the cases that my fifo interface does; that's probably why nobody else did this yet. i didn't think of the flag-to-interrupt connection because my design doesn't use interrupts. you still have to instantiate an lpm_fifo or somesuch with mine; i take it i didn't make that clear enough in the docs?
as for what's different, here's what i could think of:
[list][*]streaming mode should benefit if you're reading from a legacy-mode fifo, since iul doesn't do latency.
[*]used words/free words registers and thresholds.
[*]end-of-packet detection.
[*]can read and/or interrupt on more than one flag, and can change interrupt masks at runtime.
[*]one peripheral instead of two or three.
[*]can block master when writing to full fifo or reading empty fifo.
[*]at some point, i'll have a character driver for it, so it can work like a uart for interprocessor communication.
[*]on a dual-clock fifo, you don't have almost-full or almost-empty.
[*]it's all prefab; you don't have to recheck the timing every time.
[/list]so basically, you could do almost everything that fifo interface does with an iul, a couple pios (one for flags and one for usedw[]), and a bunch of external logic. it would just be more work.
personally, i'm not a big fan of iul; it took me quite a bit of searching to find the difference between avalon register slave and avalon memory slave; there's a cool interface for defining ports, but no way to define parameters passed to the top-level entity; and there's no way to define more than one port (e.g. one iul with both master and slave ports).
<!--quotebegin-kenland@Aug 2 2004, 04:48 PM i've had trouble achieving 100% on both streaming dma and driving a master port. would your component be a good buffer for either of these to avoid that 1% loss? --- Quote End --- I can't say without knowing what the 1% loss is from...
