13 years agoDelayed Interrupt
Nios-II response to Continuous interrupt is delayed (sometime), due to this i am loosing my data what precaution should i take to handle this issue please have a look on print screen of m...
13 years ago --- Quote Start --- It's not easy to help you without knowledge of your system implementation. I can only make a few guesses. First of all, the delay is in the 2us range. This short time is very difficult to manage in software. You excluded this delay is due to higher priority interrupts, but common hw processes, like bus arbitration, memory burst accesses or other unpredictable events can lead to a non neglectable delay in this range. What's you processor system clock frequency? Is Nios the only bus master or do you have dma? Please also specify where the irq comes from. Is this a PIO interrupt? And how do you read the data being lost? --- Quote End --- What's you processor system clock frequency? 165mhz Is Nios the only bus master or do you have dma? yes, nios the only bus master i do not have any dma Please also specify where the irq comes from. Is this a PIO interrupt? yes this is a pio interrupt And how do you read the data being lost? its visiable on la and at receiver i am not getting data also At every interrupt I read 2D array ImgBuff[460][640]
do
if(edge_capture)
//Clear generated interrupt
edge_capture = 0;
IOWR_ALTERA_AVALON_PIO_DATA(TEMP_OUT_BASE,1); //(shown on LA)
IOWR_ALTERA_AVALON_PIO_DATA(DATA_BASE,ImgBuff);//(shown on LA)
Count++;
if(Count == PktSize) //check end of packet-data
Count = 0; //Point to Start of packet data
LPktCount++; //Increment packet Count
IOWR_ALTERA_AVALON_PIO_DATA(TEMP_OUT_BASE,0); //(shown on LA)
}while(LPktCount != (PktCount+1));
