21 years agoCustom Instruction and ALU
Hi all,
In an embedded project I am developing I have implemented 2 different custom instructions (in particular 2 "External Interface Custom Instruction") with a variable Multi-Cycle. Each custom instruction has the canonical inputs and oputputs as specified in the custom instruction application note: INPUT: clk, clk_en, reset, start OUTPUT: done, result[31..0] Currently, these two custom instructions could be implemented with only one piece of logic that can serve both instructions. If I try to implement them with a single piece of logic, I get all the input and output pins twice (one for the first custom instruction, one for the second). Are there any relationship between the first custom instruction's pins and the second custom instruction's pins inside the ALU??? (For example, I would expect that clk, clk_en, reset, and other pins are simply the same signals routed once for each custom instruction...) May I simplyfy the hardware I'm writing supposing that some pins arrive only once to that unique piece of logic that serve more than one custom instruction? Thank you! Matteo1 Reply
Hi Matteo,
Dont know if it can solve your problem, but you can you custom instruction of type "extended". they are still multi-cycle, and also receive a n[1..7] vector as input. Meaning that you can fit your block of logic under only 1 custom instruction extended, but actually parameter your instruction with n[1..7]. Sylvain
