13 years agoC Program only runs on NIOS 2 IF a printf is in the code.
Hi, i am using quartus version 11.1 and i am using the tool for eclipse to make my c programs so that i can run them on the nios 2 hardware. I am using a altera de2 board.
I am working on a bigger project with VGA and keyboard and now I have made a "handshake communication" between the nios and a ram-controller. This is just so that i am not loosing any new input to the ram. But this works very slowly, and with signal tap i have found out that it is nios that are extremly slow on reading the PIO as i use as a flag to tell when its okey to send next character. I think the problem is for me in ecplise somewhere, for some reason i can not run ANY program that does not include a printf. It is like the compiler is optimizing away the code. Let me show you some examples that in my opinion should work but does not, not even on other nios system that i have created just to try, some small simple ones. Checklist: I have tried created new quartus projekt and new sopc files with new nios. I have tried a new workspace in eclipse. I have tried not changed anythings in the makefile. For 4 weeks ago, it worked without the printf (I dont think that i have changed anything in eclipse, in that case, by mistake) Ps: even programs without loops do only run with printf. So, how should i do to be able to run c programs on my NIOS 2 that does not include a printf? This will NOT work, using on_chip_memory# define swit 0x01021010# define LEDR_BASE_ADDRESS 0x01021030
int main(void)
(with or witout volatile, niether works) int * led = (int *) LEDR_BASE_ADDRESS;
volatile int * switches = (int *) swit;
while(1)
*(led) = *(switches);
return 0;
But this WORKS, using on_chip_memory: # define swit 0x01021010# define LEDR_BASE_ADDRESS 0x01021030
int main(void)
while(1)
printf("Hello");
return 0;
this will NOT work, using sdram_memory: # define lol 0x01021000# define ADDR_BASE_ADDRESS 0x01021040# define VGA_BASE_ADDRESS 0x01021030# define FLAG_BASE_ADDRESS 0x01021050
int main(void)
volatile int * flag = (int *) FLAG_BASE_ADDRESS;
volatile int * vga = (int *) VGA_BASE_ADDRESS;
volatile int * addr = (int *) ADDR_BASE_ADDRESS;
int state = 0;
*(vga) = 'a';
*(addr) = 0;
while(1)
if((*(flag) & 0x01) == 0)
if(state == 0)
*(vga) = *(vga) +1;
*(vga)= (*(vga) | 0x100);
state = 1;
else
if(state == 1){
*(vga)= (*(vga) & 0x0FF);
*(addr) = *(addr)+1;
state = 0;
return 0;
} this WILL work, using sdram_memory: # define lol 0x01021000# define ADDR_BASE_ADDRESS 0x01021040# define VGA_BASE_ADDRESS 0x01021030# define FLAG_BASE_ADDRESS 0x01021050
int main(void)
int state = 0;
*(vga) = 'a';
*(addr) = 0;
while(1)
printf("hi");
if(state == 0)
*(vga) = *(vga) +1;
state = 1;
else
if(state == 1){
state = 0;
return 0;
} SOLUTION: The problem seems to only occure when in SOPC-builder choosing Processor -> Nios_processor -> and take the II/f core. So if you get this problem just go for the II/e core and that way it worked fine for me. No RepliesBe the first to reply
