14 years agoBurst transfer using the NiosII
Hi, I had a doubt regarding the burst transfer interface on the Nios II processor. I am using the version with the data cache and hardware multipliers. I have read in some thread that we can ac...
14 years agoI believe the only way the nios can do burst memory cycles is when doing cache line fill/write.
Normal uncached avalon memory cycles are always done synchronously - ie the nios cpu stalls for the entire avalon cycle (the 'result delay' for reads happens after this stall). The 'tightly coupled data' interface isn't public - so you can't use that to interface to custome logic. A couple of options for avoiding the avalon bus stalls: 1) use a tightly coupled memory block and get your logic to transfer to from the dual port of that memory 2) access from within the custom instruction logic - needs a little lateral thought
