15 years agoAvalon-MM Tristate Bridge and custom component
I have made a design with Avalon-MM Tristate Bridge connected to a Common Flash Interface Controller (CFI) and a custom component (see https://www.alteraforum.com/forum/attachment.php?attachmentid=4775 ). Both connected to the same 80 MHz clock (12,5ns periode). The custom component and the CFI flash are sharing data/address/read_n/write_n. The chipselects are not shared. As you can see in “Description custom component:“. I want a holdTime 50ns, setupTime 50ns and a WaitTime 200ns. These parameters are also used for the Common Flash Interface Controller. Then I measure the chipselect/read signal with a scope connected to the Common Flash Interface Controller, all is working well. But the data was not correct! So I added SignalTap to see what was wrong on the interface. I used the command in the nios2 terminal: “nios2-flash-programmer --base=0x0 -R readback.bin –debug”. To see what is happening (see https://www.alteraforum.com/forum/attachment.php?attachmentid=4821 . At the trigger line you can see a data value of A8h. This is not the value I expected, I was expecting the value 34h. The value is there but the “nios2-flash-programmer” is tells me that read a value of A8h (you can see in “Error logging from nios2-flash-programmer:“. The next value I expect is also a 34h, but the “nios2-flash-programmer” tells me a value of 09h is read. This is also visible in the SignalTap image. There is some think wrong with reading the data. I do not understand this. Can anyone help me with my problem. I'm using quartus 10.1 SP1 with a cyclone 4 device. Error logging from nios2-flash-programmer:
Using cable "USB-Blaster ", device 1, instance 0x00
Resetting and pausing target processor: OK
No CFI table found at address 0x00000000
Original contents (after writing 0xF0 and 0xFF to address 0x00000000):
0: A8 09 00 04 A8 09 00 04 A8 09 00 04 A8 09 00 04 ................
10: A8 09 00 04 A8 09 00 04 A8 09 00 04 A8 09 00 04 ................
20: A8 09 00 04 A8 09 00 04 A8 09 00 04 A8 09 00 04 ................
30: A8 09 00 04 A8 09 00 04 A8 09 00 04 A8 09 00 04 ................
40: A8 09 00 04 A8 09 00 04 A8 09 00 04 A8 09 00 04 ................
Contents after writing 0x98 to address 0x000000AA:
Same after writing 0x0098 to address 0x00000154:
Same after writing 0x00000098 to address 0x000002A8:
Same after writing 0x98 to address 0x00000055:
Same after writing 0x0098 to address 0x000000AA:
Same after writing 0x00000098 to address 0x00000154:
Same after writing 0x98 to address 0x00000154:
Same after writing 0x0098 to address 0x000002A8:
Same after writing 0x00000098 to address 0x00000550:
Ignored possible autoselect code A8-A8 as no override data
present in section
Ignored possible autoselect code 09A8-09A8 as no override data
present in section
Leaving target processor paused
set_module_property DESCRIPTION ""
set_module_property NAME comp_eb_pld
set_module_property VERSION 1.0
set_module_property INTERNAL false
set_module_property OPAQUE_ADDRESS_MAP true
set_module_property GROUP own
set_module_property AUTHOR "tja"
set_module_property DISPLAY_NAME comp_eb_pld
set_module_property TOP_LEVEL_HDL_FILE ""
set_module_property INSTANTIATE_IN_SYSTEM_MODULE false
set_module_property EDITABLE true
set_module_property ANALYZE_HDL TRUE
add_interface avalon_tristate_slave avalon_tristate end
set_interface_property avalon_tristate_slave activeCSThroughReadLatency false
set_interface_property avalon_tristate_slave addressAlignment NATIVE
set_interface_property avalon_tristate_slave explicitAddressSpan 0
set_interface_property avalon_tristate_slave holdTime 50
set_interface_property avalon_tristate_slave isMemoryDevice false
set_interface_property avalon_tristate_slave isNonVolatileStorage false
set_interface_property avalon_tristate_slave maximumPendingReadTransactions 0
set_interface_property avalon_tristate_slave printableDevice false
set_interface_property avalon_tristate_slave readLatency 0
set_interface_property avalon_tristate_slave readWaitStates 200
set_interface_property avalon_tristate_slave readWaitTime 200
set_interface_property avalon_tristate_slave setupTime 50
set_interface_property avalon_tristate_slave timingUnits Nanoseconds
set_interface_property avalon_tristate_slave writeWaitStates 200
set_interface_property avalon_tristate_slave writeWaitTime 200
set_interface_property avalon_tristate_slave ENABLED true
add_interface_port avalon_tristate_slave ats_eb_pld_data data Bidir 8
add_interface_port avalon_tristate_slave ats_eb_pld_address address Input 8
add_interface_port avalon_tristate_slave ats_eb_pld_chipselect_n chipselect_n Input 1
add_interface_port avalon_tristate_slave ats_eb_pld_read_n read_n Input 1
add_interface_port avalon_tristate_slave ats_eb_pld_write_n write_n Input 1
1 Reply
major update in tests performed!
